[Qgis-developer] Re: creating a new vector layer supporting all
	line, point n polygon
    nitin quick
    quick.nitin at gmail.com
    Fri Aug 25 07:51:18 EDT 2006
hello evrybody,
today i discovered sth lse is also going wrong with plugin. After using
plugin, displaying points,  whenever i start another tool which generate a
new mesage window( like measure line, measure areaa) it cleans the canvas
and shapes marked with plugin are gone.
I think are implemented to work this way. How can i avoid such behaviour?
regards
quickNitin
On 8/24/06, nitin quick <quick.nitin at gmail.com> wrote:
> i found what wrong i was doing. i was calling updateCanvas( ) inside
> drawShape() function which in turn was resulting in call to drawShape().
> Second, slot defining visibility rectangle was not connnected.
> > Hello everybody,
> > As against my previous approach, i followed a newer one.
> > Let user put/mark on canvas as QgsMapCanvasItem  and mouse interactivity
> > using QgsMapCanvasTool.
> > But i have some issue which i couldn't sort out.
> > a. When i click on canvas ,after loading plugin , point symbol donot
> > apears until i refesh.
> > Header file look like this:-
> > /*----------vp.h-------------*/
> > class vP:public QgsMapCanvasItem, public QgsMapTool, public QgisPlugin
> >   Q_OBJECT;
> >   public:
> >   vP(QgisApp * theApplication, QgisIface * theInterface);
> >   //! Destructor
> >   virtual ~vP();
> >     //! Mouse move event for overriding
> >     virtual void canvasMoveEvent(QMouseEvent * e) { }
> >     //! Mouse press event for overriding
> >     virtual void canvasPressEvent(QMouseEvent * e) { }
> >     //! Mouse release event for overriding
> >     virtual void canvasReleaseEvent(QMouseEvent * e);
> >      void drawShape(QPainter & p);
> >      void updatePixmap();
> > public slots:
> >   //! init the gui
> >   virtual void initGui();
> >   //! Show the dialog box
> >   void run();
> >   //! unload the plugin
> >   void unload();
> >   //! show the help document
> >   void help();
> >   //!draw a raster layer in the qui
> >   void drawRasterLayer(QString);
> >   //! Add a vector layer given vectorLayerPath, baseName, providerKey
> > ("ogr" or "postgres");
> >   void drawVectorLayer(QString,QString,QString);
> >   //!will receive signal pbnOk clicked
> >     void recvOkClicked();
> > private:
> >   int mPluginType;
> >   //! Pointer to our toolbar
> >   QToolBar *mToolBarPointer;
> >   //! Pionter to QGIS main application object
> >   QgisApp *mQGisApp;
> >   //! Pointer to the QGIS interface object
> >   QgisIface *mQGisIface;
> >   //!pointer to the qaction for this plugin
> >   QAction * mQActionPointer;
> >     //! container for storing location of elements, later will be made
> > of appropriate struct
> >     QList<float > elementList;
> > here is code for drawShape()
> >     [CODE]
> >   //!This will draw the elements on to canvas
> > void vP::drawShape(QPainter &p)
> >     double temp_x, temp_y;
> >     QgsPoint qPoint(0.0,0.0);
> >     QPoint cPoint(0,0);
> >     //loading image to pixmap which will be displayed on points
> >     QString myFileNameQString= "/home1/qgis/images/vP/hit.png";
> >     QPixmap myQPixmap;
> >     myQPixmap.load(myFileNameQString);
> >     //displaying it at position where the points are marked
> >     //currently drwing all points which are is in list but only point
> > which is added latest should be drawn
> >     QListIterator<float> listIterator(elementList);
> >     cout<<"\n";
> >     while(listIterator.hasNext())
> >     {    temp_x=listIterator.next();
> >         //cout<<"\t"<<temp_x<<" ";
> >         if(listIterator.hasNext())
> >         {    temp_y=listIterator.next(); //cout<<temp_y;
> >             qPoint.setX(temp_x);
> >             qPoint.setY(temp_y);
> >             cPoint=QgsMapCanvasItem::toCanvasCoords(qPoint);
> >             p.drawPixmap(cPoint.x(),cPoint.y(),myQPixmap);
> >             show();
> >         cout<<"vp.cpp-205\t";
> >     updateCanvas();
> >     //update();
> >     cout<<"vp.cpp-210\n";
> > [/CODE]
> > I had observer that this function drawShape() is continuously being
> > called. I myself has not made any connection to it.
> > Code for canvasReleaseEvent() is :-
> > void vP::canvasReleaseEvent(QMouseEvent * e)
> >   QgsPoint point =
> > mQGisIface->getMapCanvas()->getCoordinateTransform()->toMapCoordinates(e->x(),
> > e->y());
> > if (e->button() == Qt::LeftButton)
> >     show();//why here-find out priority at 5
> >     //!make data available for storage
> >     cout<<"\nelement bein added "<<point.x()<<" "<<point.y()<<"vp.cpp-171";
> >     elementList.append(point.x());
> >     elementList.append(point.y());
> > All advices are welcome. Also i keep stucking at such situations where i
> > i have to display on canvas through interactivity with user. Will anyone
> > guide me in improving here?
> > regards
> > quickNitin
> > On 8/21/06, nitin quick < quick.nitin at gmail.com> wrote:
> > > hello everybody,
> > > Currently i am trying to create a application which let me overlay(
> > > creation of some  objects using mouse like marking something on map) some
> > > shapes over current map.
> > > For this purpose i am thinking of few steps:
> > > 1. Creating a new vector layer:
> > >                   Issue: here issue is layer supports only either
> > > lineor point or polygon but usually i want to have all of these available to
> > > me. How i can sort out this issue?
> > > 2. Add projection information ( if this is independent of underlying
> > > map's projection information)
> > > 3. Displaying it and editing it.
> > > Any advices on how i can carry out this task more effectively is
> > > welcome.
> > > regards
> > > quickNitin
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060825/bcffd64b/attachment.html
