[Qgis-developer] Howto make icons
Radim Blazek radim.blazek at gmail.com
Sun Aug 27 13:51:12 EDT 2006
On 8/27/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi Radim
> I have a template in SVN under
> qgis/images/themes/default/icon_template22x22.xcf
It seems to be raster, do you work with rasters?
> There are various layers in there that may be useful. I often grab crystal
> icons as a basis to start making a new icon with too.
Do you know where original pictures in SVG format can be downloaded?
Here are only rasters:
http://linuxcult.com/node/10, http://everaldo.com/crystal.html
Radim
> If you need any help, let me know I can whip some icons up for you....
> Regards
> Tim
> On 27/08/2006, at 04:27, Radim Blazek wrote:
> Hi,
> can you give me some hints how to create new icons?
> Which application do you use for making icons on Linux?
> How to make them? Vector pictures converted to rasters?
> Thanks
> Radim
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
