[Qgis-developer] 0.8 release grass plugin and query builder issues
Radim Blazek radim.blazek at gmail.com
Tue Aug 29 05:57:27 EDT 2006
On 8/28/06, Neil Best <nbest at speakeasy.net> wrote:
> A couple of things that I notice while playing with my shiny new QGIS:
> *  I notice that the GRASS plugin prompts you for GISBASE but won't
> allow selection of a directory.  It seems to work fine when I point it
> to /usr/lib/gras and hit cancel.
> *  QGIS crashed when I tried to go into the GRASS editor:
> No such file or directory: /driver/db/
> error_routine (fatal = 0): Cannot open driver 'dbf'
Obviously because GISBASE was not selected in previous step.
Which platform, compiled yourself? GISBASE should be compiled
into the plugin using --with-grass and you are only prompted for
GISBASE if it was removed.
What does it mean 'won't allow selection of a directory'?
Most probably the directory you selected is not GISBASE.
The dialog is checking for $GISBASE/etc/element_list.
Radim
> Cannot open database /home/neil/gis/kb/ses/grass/ses/PERMANENT/dbf/ by
> driver dbf
> mProjectionEnabled = 0
> QgsGrassEdit::setCanvasPropmt
> Segmentation fault
> I noticed that the attributes for my GRASS layers were not coming across.
> * The query builder button is greyed out for my vector layers, both
> GRASS and SHP.  Why wouldn't it be available?
> These might be bugs, but since I'm not 100% sure if I compiled correctly
> I thought I would submit them to the group and see if others see them also.
> Neil
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
