[Qgis-developer] Re: experimental win32-SVN-HEAD-snapshots
Radim Blazek radim.blazek at gmail.com
Tue Aug 29 06:59:03 EDT 2006
The problem is that WMS provider gets the srs.db path
from static QgsApplication::srsDbFilePath() which is
inited in main(). WMS provider on Windows was built with staticaly
linked core library and so the path was incorrect.
Unfortunately if I used CORE_DLL the provider fails to load
(QLibrary::open). I found that this works:
  $(CORE_A) $(GUI_DLL)
Yes, strange because QgsApplication is in core library so it
should not work! Another strange thing is that OGR provider
loads if compiled with DLL. I have submitted to SVN but
it is not final solution.
Radim
> On 8/28/06, Gary Sherman <sherman at mrcc.com> wrote:
> > On Mon, August 28, 2006 5:41 am, Stephan Holl wrote:
> > > Dear Gary,
> > > I have built an experimental win32-SVN-snapshot. Perhaps you can link
> > > it to the download-page? I have quickly tested the basic functions.
> > Great work -- but -- your snapshot has the same problem as my builds. It
> > can't find the srs.db file when doing projection related operations (eg.
> > adding a WMS site). I hesitate to put it out there until we resolve the
> > problem.
> > This is documented in https://svn.qgis.org/trac/ticket/214
> > I have been unable to fix it but haven't spent a lot of time on it.
> > Perhaps Radim has an idea?
> > -gary
> > -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
> > Gary Sherman
> > Micro Resources: http://mrcc.com
> >   *MapServer Hosting
> >   *Web Site Hosting
> > "We work virtually everywhere"
