[Qgis-developer] Cannot print lines to postscript
Radim Blazek
radim.blazek at gmail.com
Wed Dec 6 03:05:34 EST 2006
On 12/5/06, Maciej Sieczka <tutey at o2.pl> wrote:
> The only glitch still remaining for me, which I also have mentioned in
> the #345 in Trac, is that although the "Print to file" is checked by
> default, the dialog for entering the path to file is not active;
> printers are listed instead; see the attached screenshot.
> I have to uncheck it and check it back for the path dialog to become
> active.
Yes, known bug in Qt. I presume that printing to file is more frequent
then printing to printer, but until they fix it in Qt it will be better to
use printer as default. I'll change it.
Radim
> QT 4.2.2, QGIS SVN 6190
> Maciek
