[Qgis-developer] crash loading project
Martin Dobias
wonder.sk at gmail.com
Tue Dec 19 08:53:10 EST 2006
Hi Paolo,
does it happen also with current SVN trunk? If so it would be good if
you could file a ticket for that and attach data, if possible provide
also backtrace.
Martin
On 12/18/06, Paolo Cavallini <cavallini at faunalia.it> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all.
> While loading a project, the last qgis (package from debian.gfoss.it)
> crashes:
> Debug: qgsproject.cpp:1065 5 properties read
> Debug: current properties:
> Debug: name: properties
> Debug: key: <SpatialRefSys> subkey: <SpatialRefSys>
> Debug: name: SpatialRefSys
> Debug: key: <ProjectSRSProj4String> value:
> +proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000 +y_0=0
> +ellps=intl +units=m +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> Debug: key: <ProjectionsEnabled> value: 0
> Debug: key: <ProjectSRSID> value: 100000
> Debug: key: <Compositions> subkey: <Compositions>
> Debug: name: Compositions
> Debug: key: <composition_1> subkey: <composition_1>
> Debug: name: composition_1
> Debug: key: <width> value: 297
> Debug: key: <height> value: 420
> Debug: key: <map_1> subkey: <map_1>
> Debug: name: map_1
> Debug: key: <width>
> value: 290
> Debug: key: <west>
> value: 1642464.22358776
> Debug: key: <fontscale>
> value: 1
> Debug: key: <x> value: 3
> Debug: key: <y> value: 3
> Debug: key: <calculate>
> value: scale
> Debug: key: <scale>
> value: 10446.6798556688
> value: 414
> Debug: key: <south>
> value: 4821062.78963389
> Debug: key: <frame>
> value: true
> Debug: key:
> <widthscale> value: 1
> Debug: key:
> <symbolscale> value: 0.5
> Debug: key:
> <previewmode> value: 0
> Debug: key: <east>
> value: 1645493.7607459
> Debug: key: <north>
> value: 4823882.24939786
> Debug: key: <orientation> value: portrait
> Debug: key: <resolution> value: 300
> Debug: key: <Gui> subkey: <Gui>
> Debug: name: Gui
> Debug: key: <SelectionColorBluePart> value: 0
> Debug: key: <SelectionColorGreenPart> value: 255
> Debug: key: <SelectionColorRedPart> value: 255
> Debug: key: <CanvasColorBluePart> value: 255
> Debug: key: <CanvasColorRedPart> value: 255
> Debug: key: <CanvasColorGreenPart> value: 255
> Debug: key: <PositionPrecision> subkey: <PositionPrecision>
> Debug: name: PositionPrecision
> Debug: key: <DecimalPlaces> value: 2
> Debug: key: <Automatic> value: true
> Debug: key: <Digitizing> subkey: <Digitizing>
> Debug: name: Digitizing
> Debug: key: <Tolerance> value: 10
> Debug: key: <LineWidth> value: 1
> Debug: key: <LineColorGreenPart> value: 0
> Debug: key: <LineColorBluePart> value: 0
> Debug: key: <LineColorRedPart> value: 255
> Debug: qgsproject.cpp : 680 unable to find title element
> Warning: QgsSpatialRefSys::getRecord failed : select * from tbl_srs
> where parameters='+proj=tmerc +lat_0=0 +lon_0=9 +k=0.999600 +x_0=1500000
> +y_0=0
> +ellps=intl +units=m +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68'
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x810456a
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x81b243a
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x858a442
> ERROR 5: Access window out of range in RasterIO(). Requested
> (6840,5093) of size 441x1067 on raster of 7280x6160.
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x882164a
> (120,5213) of size 7201x907 on raster of 7320x6120.
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x8cb3b7a
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x8472a7a
> Debug: qgslabel.cpp:607 QgsLabel::readXML() got node labelattributes
> +y_0=0 +ellps=intl +towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
> +units=m +no_defs'
> +units=m +no_defs'
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x8ffb85a
> +units=m +no_defs'
> +units=m +no_defs'
> qgsrasterlayer.cpp:4605 Setting gray band to : 0x9002aba
> Segmentation fault
> Paolo Cavallini
> email+jabber: cavallini at faunalia.it
> www.faunalia.it
> Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFFhrNS/NedwLUzIr4RAqtLAJ9GGGke9dlQZqUT5O6yxK4+jgBlvACeIRmW
> erH92eDWHSAsE2Ze7LVVu5s=
> =EBEv
> -----END PGP SIGNATURE-----
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
