[Qgis-developer] qgis 0.8pre2 on suse10.2
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Dec 19 17:37:13 EST 2006
Hello Otto,
Look for an rpm called something like qt4-devel for your distribution -
the devel packages are what usually install the header files.
Mike
Otto Dassau wrote:
> Hi,
> I try to compile qgis pre2 on an opensuse 10.2 with qt4.2.1. QGIS doesn't
> find the header files like qglobal.h under /usr/lib/qt4/include. They don't
> exist and I don't know what further packages I need to install, because I
> thinkt I already installed all qt4 rpms that come with the distribution.
> Under download.qgis.org/qgis/ there is already a
> qgis-0.8.0_preview-1_no_grass.i586.rpm for suse 10. Was this package built using
> qt4 from suse or using compiled qt4 sources?
> Maybe someone knows a trick how to build the preview2 under suse 10.
> thanks a lot
> Otto
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
