[Qgis-developer] qgis 0.8pre2 on suse10.2
Otto Dassau otto.dassau at gmx.de
Wed Dec 20 15:00:51 EST 2006
thanks a lot for your help I will try another time. For today I changed back to
stable geos 2.2.3 and it compiled without any problems.
I finally created QGIS and related GIS rpm packages. If you like you can
download the software here:
RPM and SRPM:
http://www.nature-consult.de/software/suse/10.2/
best,
 Otto
On Wed, 20 Dec 2006 10:05:21 -0500
Mike Leahy <mgleahy at alumni.uwaterloo.ca> wrote:
> Otto,
> There is a patch posted on the developer list:
> http://lists.qgis.org/pipermail/qgis-developer/2006-December/001218.html
> This will let you compile QGIS 0.8 prerelease 2 with GEOS-3.0.0rc3 (but
> not 2.x).  There's another patch for the SVN unstable branch that allows
> compiling against either of 3.x/2.x in a follow-up message:
> http://lists.qgis.org/pipermail/qgis-developer/2006-December/001227.html
> I wouldn't say that these are officially approved patches, but it'll
> probably do the trick for you.
> The patches are renamed to *.bin files in the archive, but it's still
> plain text, so I think you should be able to use them.
> Regards,
> Mike
> Otto Dassau wrote:
> > Hi,
> > thanks for the hint, the devel packages were in /usr/include/Qt, so
> > export QTDIR=/usr works.
> > Now I have another problem. SuSe 10.2 unfortunately doesn't include GEOS, so
I
> > compiled and installed current GEOS-3.0.0rc3 and QGIS complains because it
> > expects a GEOS 2.x.x Version.
> > Where and what do I have to change to adapt the test? Or do I need to stick
with
> > GEOS 2.x.x?
> >  thanks again
> >   Otto
> > On Tue, 19 Dec 2006 17:37:13 -0500
> >> Hello Otto,
> >> Look for an rpm called something like qt4-devel for your distribution -
> >> the devel packages are what usually install the header files.
> >> Mike
> >> Otto Dassau wrote:
> >>> Hi,
> >>> I try to compile qgis pre2 on an opensuse 10.2 with qt4.2.1. QGIS doesn't
> >>> find the header files like qglobal.h under /usr/lib/qt4/include. They
don't
> >>> exist and I don't know what further packages I need to install, because I
> >>> thinkt I already installed all qt4 rpms that come with the distribution.
> >>> Under download.qgis.org/qgis/ there is already a
> >>> qgis-0.8.0_preview-1_no_grass.i586.rpm for suse 10. Was this package built
> > using
> >>> qt4 from suse or using compiled qt4 sources?
> >>> Maybe someone knows a trick how to build the preview2 under suse 10.
> >>> thanks a lot
> >>>  Otto
> >>> _______________________________________________
> >>> Qgis-developer mailing list
> >>> Qgis-developer at lists.qgis.org
> >>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
