[Qgis-developer] Mac OS X vertex limitation
Gary Sherman sherman at mrcc.com
Sun Dec 31 22:37:28 EST 2006
On Dec 31, 2006, at 3:52 PM, William Kyngesburye wrote:
> There's a note in the Mac Qgis readme about the Mac build being
> limited in the number of vertices per polygon due to a QuickTime
> limitation (actually that's a QuickDraw limitation) as used in Qt.
> Is this still valid?
I'm not sure, maybe Tom knows...
> I looked at the Qt docs for QPainter and Qt4 should be able to use
> OSX's CoreGraphics now.  Unless maybe Qgis is still using a Qt3
> compatibility thing and stuck on the QuickDraw method?  Though I'm
> not sure if CoreGraphics has removed that vertex limitation or not
> (one would think so).
We aren't using Qt3 compat for drawing so this shouldn't be an issue.
I can easily test with my dataset once there is a Mac build available.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
"We work virtually everywhere"
