[Qgis-developer] PKG_CHECK_MODULES / pkg-config
Radim Blazek radim.blazek at gmail.com
Thu Jul 6 07:44:59 EDT 2006
my configure (without --with-qt-pkg-config) fails with:
/configure.orig: line 9149: syntax error near unexpected token `QT,'
./configure.orig: line 9149: `    PKG_CHECK_MODULES(QT, QtCore QtGui
Qt3Support QtNetwork QtXml QtSvg QtTest >= $QT_MIN_VER)'
I have pkg-config version installed (version 0.20) on Ubuntu  6.06 LTS
(Dapper Drake).
It seems that PKG_CHECK_MODULES simply is not defined and consequently
bash fails even if the block is not processed.
Is it necessary to use PKG_CHECK_MODULES? It seems to be just another
shit like all the auto* staf is.
Radim
