[Qgis-developer] more fun with 0.8 compiling on OS X
Kirk R. Wythers kwythers at umn.edu
Thu Jun 8 15:34:51 EDT 2006
searchstringparser?
Thanks Tom for the tips about configure. Now that I'm past that I am
pulling (what little) hair I have left over this one:
barbaloot:~/src/qgis_unstable kwythers$ make
make  all-recursive
Making all in src
Making all in core
bison -y  -d qgssearchstringparser.yy
qgssearchstringparser.yy:110: invalid input: ;
make[3]: *** [qgssearchstringparser.cc] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
I did the "comment out the $QTDIR/lib/libQtTest.la and remove or
comment the line beginning dependency_libs=" step in /usr/local/
Trolltech/Qt-4.1.3/
The config script returned:
qgis 0.8.0
GDAL/OGR      : yes (Version 1.3.0)
GEOS          : yes (Version 2.1.2)
PostgreSQL    : yes (Version 8.0.3)
GRASS         : yes
SPIT          : yes
Georeferencer : yes
GPS/GPX       : yes
PROJ4         : yes
SQLITE3       : yes
Python        : no
Debug         : no
Plugin dir    : ${exec_prefix}/lib/qgis
The binary will be installed in /Users/kwythers/src/qgis_stable_07/
src/qgis.app/Contents/MacOS
The build is using Qt in /usr/local/Trolltech/Qt-4.1.3
Linking with Qt using -Xlinker -F/usr/local/Trolltech/Qt-4.1.3/lib -
framework Qt3Support -framework QtCore -framework QtGui -framework
QtNetwork -framework QtXml -framework QtSvg -L/usr/local/Trolltech/
Qt-4.1.3/lib -lQtDesigner -lQtTest
Configure finished, type 'make' to build.
and $QTDIR is set to:
# Qt4 environment
QTDIR=/usr/local/Trolltech/qt-mac-opensource-src-4.1.3
PATH=/usr/local/Trolltech/Qt-4.1.3/bin:$PATH
DYLD_LIBRARY_PATH=$QTDIR/lib:$DYLD_LIBRARY_PATH
export QTDIR PATH MANPATH DYLD_LIBRARY_PATH
