[Qgis-developer] postgis load error on 0.8
Kirk R. Wythers kwythers at umn.edu
Fri Jun 9 12:13:24 EDT 2006
I am trying to load a postgis view in a a new build of 0.8 qgis. The
error returned complains about now column being usable as a unique
key. The error then goes on to list the columns and give discriptions
(very useful feature by the way). However, there is a column in the
view that is unique, and the error message declares that it is
suitable. The column is 'gid' and is reported in the error message a
suitable. Is this a bug?
Thanks,
Kirk
The view 'publicall_timber_data'has no column suitable for use as a
unique key.
Qgis requires that the view has a column that can be used as a unique
key. Such a column should be derived from a table column of type int4
and be a primary key, have a unique constraint on it, or be a
PostgreSQL oid column. To improve performance the column should also
be indexed.
The view you selected has the following columns, none of which
satisfy the above conditions:
'area' derives from 'public.mn_pls_grid.area' and is not suitable
(type is numeric and does not have a suitable constraint)
'cords' derives from 'public.timber_volume.cords' and is not suitable
(type is int4 and does not have a suitable constraint)
'county_name' derives from 'public.county.county_name' and is not
suitable (type is varchar and does not have a suitable constraint)
'forty_name' derives from 'public.forties.forty_name' and is not
'gid' derives from 'public.mn_pls_grid.gid' and is suitable.
'mbm' derives from 'public.timber_volume.mbm' and is not suitable
'perimeter' derives from 'public.mn_pls_grid.perimeter' and is not
suitable (type is numeric and does not have a suitable constraint)
'poles' derives from 'public.timber_volume.poles' and is not suitable
'posts' derives from 'public.timber_volume.posts' and is not suitable
'range' derives from 'public.mn_pls_grid.range' and is not suitable
(type is int2 and does not have a suitable constraint)
'rdir_name' derives from 'public.rdir.rdir_name' and is not suitable
'rdir_shortname' derives from 'public.rdir.rdir_shortname' and is not
'section' derives from 'public.mn_pls_grid.section' and is not
suitable (type is int2 and does not have a suitable constraint)
'the_geom' derives from 'public.mn_pls_grid.the_geom' and is not
suitable (type is geometry and does not have a suitable constraint)
'township' derives from 'public.mn_pls_grid.township' and is not
'tt_name' derives from 'public.timber_type.tt_name' and is not
'tt_shortname' derives from 'public.timber_type.tt_shortname' and is
not suitable (type is varchar and does not have a suitable constraint)
'year' derives from 'public.timber_volume.year' and is not suitable
