[Qgis-developer] Mac build issues when using William's
graphicslibs and gislibs...
Tim Sutton
tim at linfiniti.com
Sat Jun 17 21:09:53 EDT 2006
Hi
Great Ill download fresh copies of your libs and see if the problem
is resolved. The versions referred to in the mail below are
graphicslibs30 and gislibs30. If I recall there is a similar env var
that can be set for gdal's search path for plugins.
Regards
Tim
On 17/06/2006, at 12:34, William Kyngesburye wrote:
> On Jun 17, 2006, at 8:05 AM, Tim Sutton wrote:
>> Hi William
>> Im tryng to build qgis on macbook using your graphicslibs and
>> gislibs packages. However as best I can tell, one of the configure
>> scripts is adding /usr/local/static/ to the lib search path. Do
>> you have stuff built into /usr/local/static/ on your machine where
>> you prepared the packages that perhaps hasnt made it into your
>> packages?
> I try to remember to remove that stuff from the various config
> scripts (like gdal-config). It's certainly annoying that static
> libraries get added to those distributed config scripts. I may
> have missed something. Which version of my packages? I just
> cleaned up a bunch of stuff for 3.1, including double-checking
> those scripts. Getting those online is on my list to do this
> morning. Check back in a half hour.
>> Also Im curious about your xcode setup. Ive never used xcode aside
>> from installing it to get my command line build environment set
>> up. Is there an xcode project for qgis you could share? Does it
>> have nice facilities for interactive debugging etc?
> Same here - just for the command line stuff. I just call it Xcode,
> even tho I'm just using gcc and friends. I've heard the debugging
> environment is nice, but I don't really do C programming myself,
> just porting. I know enough to hack fixes and patches and get into
> trouble ^_^
> PS. I tried building PROJ with a relative path to share/proj. Proj
> commands, and probably other stuff like gdal, had no problem with
> that, but MapServer did. Probably because the relative path is
> from whatever is using the library, ie bin/proj|gdal -> ../share/
> proj, but MapServer is is a completely different location (either
> CGI folder or PHP ext folder).
> It could be made to work, but it would be a totally separate
> build. Better to use the PROJ_LIB var. Does QGIS do this
> already? Same for GDAL.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> Theory of the Universe
> There is a theory which states that if ever anyone discovers
> exactly what the universe is for and why it is here, it will
> instantly disappear and be replaced by something even more
> bizarrely inexplicable. There is another theory which states that
> this has already happened.
> -Hitchhiker's Guide to the Galaxy 2nd season intro
Tim Sutton
