[Qgis-developer] ZX
Mateusz Łoskot mateusz at loskot.net
Wed May 3 12:50:01 EDT 2006
Radim Blazek wrote:
> Hi all,
> after successful PDA port:
> http://mpa.itc.it/radim/qgis/qgis-0.0.9-grass/ipaq1.png
> http://mpa.itc.it/radim/qgis/qgis-0.0.9-grass/ipaq2.png
Great!
Radim, is there any HOWTO related to QGIS on iPAQ?
I'd be interested :-)
> I am working to port QGIS to ZX Spectrum:
> http://mpa.itc.it/radim/qgis/zx/img_0775.jpg
> http://mpa.itc.it/radim/qgis/zx/img_0776.jpg
> http://mpa.itc.it/radim/qgis/zx/img_0773.jpg
Heh, amazing!
Would you know if there could be a chance to use Commodore PLUS/4 for
such experiments?
> The work goes well but there are some issues  we have to sort out:
> 1. Small memory. ZX Spectrum comes only with 48 kB of memory and my
> current SVN trunk installation takes about 250 MB on Linux. I think
> that we can resolve a lot if we strip binary and libraries. Also,
> just one (default) icon theme and limited set of SVG symbols sould be
>  sufficient. The rest can be possibly resolved with some kind of
> compressed file system?
There may be some problems with compressed FS. I remember I had problems
with uncompressing Linux kernel on 360KB. Finally, I stripped it from
unused stuff. It was doable because the kernel is much smaller than QGIS
binary. Stripping QGIS may be a challange.
> 2. C++.  So far I have not found a good C++ compiler fo ZX Spectrum.
Me too. I don't think you will find C++ compiler for ZX.
May be there is some cross compiler similar to z88
(http://z88dk.sourceforge.net)
> It is not problem to get C compiler however. I suggest to use C++
> preprocessor on some different machine and then compile pure C on ZX
> Spectrum. I have no idea however how exceptions can be supported in
> that case. I know  that it would be possible to use cross-compiler
> and produce binaries for ZX Spectrum on Linux but it does not seem to
>  be fair enough to use such a practice known from proprietary
> software development.
Yup, you're right.
> 3 Qt. It seems that at moment Qt is not available for ZX Spectrum. I
> hope that Trolls are going to release Qt for ZX Spectrum with 4.3, at
>  least I have heard such rumors.  In case it does not happen I will
> start petition for ZX port of Qt which will be sent to Trolls. I
> don't think we have enough resources to port Qt ourselves.
Hmm, I'd bet they have something like this but I'd not be surprised if
only for internal usage/experiments (similarly, to Windows CE support).
> If you are interested to support ZX Spectrum port, we are currently
> looking for a sponsor to buy a new _green_ display as it is realy
> tiring to watch black and white screen all the day and night . If you
>  want to donate a green display, please contact directly
> Jan.Nonner at mt.com, director of ZXLabs in Roudnice. I cannot assure
> you however that you can reduce taxes in that case.
I see it's a kind of wider initiative ;-)
Could you share your opinion about possible bussines/targets for QGIS on
ZX? May be it could be used as a mobile platform for navi systems in
cars or something like this.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
