[Qgis-developer] Failed to load NAD27-83 correction file
Gary Sherman sherman at mrcc.com
Thu May 4 16:35:26 EDT 2006
Radim Blazek wrote:
> Hi,
> I have got this error on windows. I have to inspect how/where
> to install those files (if possible, because the files are binary
> and I worry that it is difficult to recompile them with crosscompiler).
In the last version, we installed the correction files in:
 "$INSTDIR\proj_lib"
  File "proj_lib\GL27"
  File "proj_lib\MD"
  File "proj_lib\TN"
  File "proj_lib\WI"
  File "proj_lib\WO"
  File "proj_lib\conus"
  File "proj_lib\epsg"
  File "proj_lib\epsg-deprecated"
  File "proj_lib\esri"
  File "proj_lib\esri.extra"
  File "proj_lib\hawaii"
  File "proj_lib\nad.lst"
  File "proj_lib\nad27"
  File "proj_lib\nad83"
  File "proj_lib\ntv1_can.dat"
  File "proj_lib\null"
  File "proj_lib\other.extra"
  File "proj_lib\proj_def.dat"
  File "proj_lib\prvi"
  File "proj_lib\stgeorge"
  File "proj_lib\stlrnc"
  File "proj_lib\stpaul"
  File "proj_lib\world"
The installer then set the required environment variable PROJ_LIB:
	PROJ_LIB=$INSTDIR\proj_lib
Further information on this can be found at http://proj.maptools.org/
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
  "We work virtually everywhere"
Quantum GIS: http://qgis.org
