[Qgis-developer] Qt 4.X
Tim Sutton tim at linfiniti.com
Thu May 11 17:43:06 EDT 2006
Hi
Your system seems to have an old version of Qt on it as well
Can you paste the result of:
rpm -qa |grep qt
How did you install Qt? From source or rpm?
Regards
Tim
On 5/10/06, Prashanth Chintamaneni <pchintamaneni at gmail.com> wrote:
> I have downloaded and installed QT3.3.6. Configuration was ok but when
> I build it this is error that I am getting
> uic: File generated with too recent version of Qt Designer (3.3 vs. 3.1.2)
> make[2]: *** [qgsmapserverexportbase.uic.h] Error 1
> Thanks,
> Prasanth.
> On 5/10/06, Tim Sutton <tim at linfiniti.com> wrote:
> > Hi
> > QGIS 0.7.4 requires Qt 3.x not Qt4.x
> > Regards
> > Tim
> > > hi,
> > > qgis-0.7.4, from source, I installed qt4.x to a directory name QT4.
> > > the operating system is SUSE Linux 9. i have added the qtdir to the
> > > configure options. It is not able to find the library files "error:
> > > *** Couldn't find any Qt libraries in /store/home/prasanth/QT4/lib".
> > > But I have all the files in there???
> > > Thank you,
> > > Prasanth.
> > > > Hi
> > > > Can you give more information please?
> > > > Which version of QGIS?
> > > > Where did you install qt4.x to?
> > > > How did you install it (from package or source)?
> > > > What OS  and or distro are you using?
> > > > Not knowing any of these answers I can take a stab in the dark anywy
> > > > and suggest you set the QTDIR environment variable appropriately and
> > > > then add the qtdir to the configure options. e.g. (on my Ubuntu Dapper
> > > > system with Qt installed from package):
> > > > export QTDIR=/usr
> > > > ./autogen.sh $AUTOGEN_FLAGS --prefix=/usr  --with-qtdir=$QTDIR
> > > > Hope that helps...
> > > > Tim
> > > > > Hello,
> > > > > I am trying to install QT4.1.2. I think I installed it right. The qgis
> > > > > installation cannot find libqt.so? Is there any modification that I
> > > > > need to make to the configure script?
> > > > > Thank you,
> > > > > Prasanth.
> > > > > _______________________________________________
> > > > > Qgis-developer mailing list
> > > > > Qgis-developer at lists.qgis.org
> > > > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > > > Tim Sutton
> > > > Visit http://qgis.org for a great Open Source GIS
> > > > Skype: timlinux
> > > > MSN: tim_bdworld at msn.com
> > > > Yahoo: tim_bdworld at yahoo.com
> > > > Jabber: timlinux
> > > > Irc: timlinux on #qgis at freenode.net
> > Tim Sutton
> > Skype: timlinux
> > Jabber: timlinux
Tim Sutton
Skype: timlinux
Jabber: timlinux
