[Qgis-developer] Point shift in map composer
Gavin Macaulay gavin at macaulay.co.nz
Tue May 16 16:32:34 EDT 2006
Radim,
The fix for ticket #86 (https://svn.qgis.org/trac/ticket/86), done in
SVN revision 5448 (https://svn.qgis.org/trac/changeset/5448) is a recent
commit that may have affected map composer, but as far as I was aware,
that code that was changed only affected the legend, not the map itself.
You could try checking out revision 5447 to see if that resolves your
problem.
Regards
Gavin
Radim Blazek wrote:
> Points in vectore layers in map composer are shifted.
> Lines and polygons are correct and all vetor layers are printed by the
> same draw() method. the shift depends on symbol scale.
> It was working in 0.7.
> Can you point me to changes in 0.8 which could cause this problem?
> Radim
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
