[Qgis-developer] Qt Minimum Version
Tom Elwertowski telwertowski at comcast.net
Fri Nov 24 21:29:31 EST 2006
Hi all,
Would it be a problem to make Qt 4.2 the minimum version for QGIS 8.0?
The API has been changed to provide better Mac-compatibility. Moving to
Qt4.2/Mac without using the new API, however, results in a decline in
the appearance of Mac buttons.
In Qt4.0/Mac, adjacent buttons that ought to have the same size don't.
This has been fixed by adding a QDialogButtonBox layout class. Using
this class, however, will make QGIS unbuildable for < Qt 4.2.
The QMessageBox API has also been changed to support cross-platform
button layouts. In addition to better looking button sizes on a Mac,
QDialogButtonBox and the new QMessageBox automatically swap the
affirmative and cancel buttons so that the affirmative button is on the
right for a Mac (where it belongs :) ).
Another benefit of Qt4.2/Mac is that a Mac crash when closing the QGIS
Attribute Table window has been fixed. There is a new Mac crash,
however, when opening the Vector Properties dialog. Since Raster
Properties opens ok, it may be a case of needing to update something. I
have found that removing Qt3 compatibility calls sometimes fixes
Mac-only problems. Perhaps obsolete Qt4.0 routines are now causing Mac
problems as well.
Tom
