[Qgis-developer] Rendering with transparency -- slow
Christoph Spoerri cspoerri at cavtel.net
Wed Nov 29 23:40:26 EST 2006
Hi there,
I diagrammed the data model currently used by the lib_refactoring branch.
While trying to understand the interaction of the classes and their purpose,
I saw that some classes share similar functions (e.g. nextFeature in layer
and provider classes), at the same time some classes could be further
refactored.
So, I went ahead and created a proposed data model, the way I would have
designed it. The idea behind the model is that we have two main classes:
- QgsDataSet: used for data manipulation on a feature level (e.g. adding,
deleting, etc.), used in QgsMapLayer for rendering. This class would contains
methods such as nextFeature(), deleteFeature(), updateGeometry(),
createPyramid(), etc.
- QgsDataProvider: used for data manipulation on a dataset level, e.g.
copy/deleting an entire dataset, format conversion, select subset of
features, etc.
The QgsMapLayer classe(s) would only be used for rendering purposes, and
methods such as nextFeature, etc would be remove from the class.
Please let me know what you think. If folks think this approach makes sense, I
would be happy to continue developing the model and post my progress for
comments on the wiki site.
cheers,
Christoph
Name: Datamodel (current).png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20061129/ae24af07/Datamodelcurrent.png
Name: Datamodel (proposed).png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20061129/ae24af07/Datamodelproposed.png
