[Qgis-developer] QGIS 0.8 preview 2 tarball available
Gavin Macaulay gavin at macaulay.co.nz
Wed Sep 13 17:12:29 EDT 2006
Willam & Pascal,
Now there's a problem with svnversion that I didn't think about when I
added it in! Yes, of course, we should setup the tarball so that it
doesn't require the svnversion program. For the moment, make up a
svnversion.h file with contents of:
#define QGSSVNVERSION "anything_here"
and also comment out the lines from ".PHONY : qgssvnversion.h" and below
in the Makefile.am (all in the top qgis directory), and things should
work fine. Someone (maybe me) will alter the Makefile.am so that it will
cope without svnversion for future tarballs.
Regards
Gavin
William Kyngesburye wrote:
> A bit of a problem - I see a new target added to make
> "qgssvnversion.h", which needs the 'svnversion' command.  I don't have
> subversion installed, and noone should need it for downloading
> tarballs of source (either premade, like the preview 2, or generating
> one from the svn web interface).  The last svn tarball I downloaded
> from the web interface, 2006-7-29 (after preview 1) doesn't have this
> qgssvnversion.h target.
> Am I stuck without installing subversion?  Can I disable it (and
> remove it from the 2 source files I found it in)?  Or can I get a
> premade qgssvnversion.h?
> On Sep 12, 2006, at 11:29 PM, Tim Sutton wrote:
>> Hi
>> I have uploaded a svn export tarball for the tagged preview branch to:
>> http://qgis.org/uploadfiles/qgis_Release-0_8-preview-2.tar.gz
>> I will make an announcement on the site tomorrow and update it as
>> binaries become available.
>> Note if you are building binaries, please check your version of
>> configure.in has the extra version set to 2 - I committed this after
>> tagging.
> William Kyngesburye <kyngchaos at kyngchaos.com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
