[Qgis-developer] Re: remove(dir) fails on Windows
Radim Blazek radim.blazek at gmail.com
Fri Sep 22 13:17:43 EDT 2006
On 9/22/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> Hi.
> remove() directory fails on Windows so that vectors cannot be deleted
> without error. Patch for lib/vector/Vlib/map.c is attached.
> IMPORTANT!
Much worse is that a vector open in QGIS cannot be deleted.
Open file on Windows cannot be deleted nor moved.
That is very bad because it is very common to run a module
again and again and watch results on display.
I don't have any idea what could be done.
Radim
