[Qgis-developer] HEAD fails to compile
Tom Elwertowski telwertowski at comcast.net
Fri Apr 13 16:02:57 EDT 2007
Gary Sherman wrote:
> Has there been a change in the GEOS dependency?
> /home/gsherman/development/qgis_09/src/core/qgsgeometry.cpp: In static
> member function 'static QgsGeometry* QgsGeometry::fromPolyline(const
> QgsPolyline&)':
> /home/gsherman/development/qgis_09/src/core/qgsgeometry.cpp:91: error:
> no matching function for call to
> 'geos::CoordinateSequenceFactory::create(int, int) const'
> /usr/local/include/geos/geom.h:993: note: candidates are: virtual
> geos::CoordinateSequence*
> geos::CoordinateSequenceFactory::create(std::vector<geos::Coordinate,
> std::allocator<geos::Coordinate> >*) const
This appears to be new code but it does compile for me using geos/Ubuntu
2.2.1, geos/Mac 2.2.3 and geos/Mac 3.0.0rc4.
Pehaps you have an older geos? Is
virtual CoordinateSequence *create(unsigned int size, unsigned int dims)
const;
declared in geom.h?
Tom
