[Qgis-developer] postgis hangs up
Paolo Cavallini cavallini at faunalia.it
Tue Apr 17 16:04:35 EDT 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Further info: this happens only for layers I do not have privileges on.
In any case, I get a lot of warnings:
Debug: Accesso alla relazione buttare_superficie_notte_afv_2007 usando
sql;select GeometryType("wkb_geometry") from
"pi_cens"."buttare_superficie_notte_afv_2007" where "wkb_geometry" is
not null limit 1 � fallito. Il database dice: ERROR:  permesso negato
per la relazione buttare_superficie_notte_afv_2007
Apparently it scans all geometry columns, which could explain the long
connection time.
All the best.
pc
Paolo Cavallini ha scritto:
> Hi all.
> Now qgis compiles, but when trying to add a PostGIS layer it hangs up,
> until I have to kill it.
> pc
Paolo Cavallini
http://www.faunalia.it/pc
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGJShT/NedwLUzIr4RAg9OAJ9ETosEQt7X/qWR++zPKkSSRLvZ0gCfVpvN
MSG+pD0rVvt8QaC1ZKu6w60=
=GGgs
-----END PGP SIGNATURE-----
