[Qgis-developer] about ogr provider
sebastian sauer scb at lo-res.org
Wed Aug 1 03:17:16 EDT 2007
Mon 30 Jul 2007 19:38, Marco Hugentobler wrote:
> The ogr provider is mostly used for reading shapefiles and GML. Afaik those
> datasources have only one layer per file (which fits perfectly with the
> approach in qgis).
> Is it possible that oracle, mysql, postgresql in ogr have multiple layers per
> datasource?
i dont know for oracle, mysql, postgresql but ogr supports that if the
fileformat allows it.. cf. e.g. the GRASS OGR driver..
http://www.gdal.org/ogr/drv_grass.html
(note however layered files are not that common in the standard use of
GRASS GIS)
> If yes, then we should think about how to handle that in QGIS.
> I'm in favour that the plugin asks the ogrprovider how many layers are
> present
that sounds reasonable..
> and the plugin then creates one Vectorlayer for each ogr layer.
that's not such a good idea. before any layer is created QGIS the
user should have the possibility to select the layers s/he wants.
my cent,
s.
