[Qgis-developer] change in QGIS-GRASS interface?
Tim Sutton tim at linfiniti.com
Mon Aug 13 08:51:46 EDT 2007
Hi
As far as I remember there have been no changes in teh GRASS stuff
since 0.8.x but it may be worth having a look at the svn log command
and see if you can find something.
Regards
Tim
2007/8/1, Leonardo Lami <lami at faunalia.it>:
> Maybe it is linked to another bug:
> see:
> http://svn.qgis.org/trac/ticket/738
> Leonardo Lami ha scritto:
> > Hi all,
> > I developed a series of QGIS-GRASS modules that are tested on QGIS vers
> > 0.8 and vers 0.8.1 with good results.
> > In the new vers (0.9) I see that there are some problems, when the same
> > modules must show the fields of table linked to the chosen vector. For
> > example the module that use the GRASS command v.to.rast with the option
> > to convert a vector to raster using attribute values is:
> > <?xml version="1.0" encoding="UTF-8"?>
> > <!DOCTYPE qgisgrassmodule SYSTEM "http://mrcc.com/qgisgrassmodule.dtd">
> > <qgisgrassmodule label=" v.to.rast - Convert a vector to raster using
> > attribute values" module="v.to.rast">
> >     <option key="input" layeroption="layer"/>
> >     <field key="column" layer="input" type="integer,double"
> > label="Attribute field" />
> >     <option key="output"/>
> >     <option key="use" answer="attr" hidden="yes" />
> > </qgisgrassmodule>
> > The string:
> > show in the module window a string where you can choose the field to use
> > as cell raster value between all the integer or double field of the
> > linked table.
> > Now in the vers 0.9 the same module, and the similar ones, don't
> > work because the string where you could choose the field is now empty.
> > There is same changes in the relation with GRASS?
> > Or something to explain it?
> > Thanks.
> > Leonardo
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
