[Qgis-developer] QgsRasterLayer::drawMultiBandColor
    Peter Ersts
    ersts at amnh.org
    Thu Aug 16 14:23:16 EDT 2007
Marco,
Just to clarify are you saying that the no-data-value is different for
each band/channel in your image?
If the bands use the same nodatavalue then technically checking just the
red channel should be sufficient, though there is a question in the code
regarding whether all channels should be checked. Additionally, with the
QgsRasterLayer in trunk you can not manually set the no-data-value. This
was updated in the raster transparency branch, so that you can manually
set the nodatavalue.
If you want to make the change anyway, then I would suggest
if((myRedValueDouble == noDataValueDouble || myRedValueDouble !=
myRedValueDouble) && (myGreenValueDouble == noDataValueDouble ||
myGreenValueDouble != myGreenValueDouble) && (myBlueValueDouble ==
noDataValueDouble || myBlueValueDouble != myBlueValueDouble))
if the nodatavalue is NaN, I believe that NaN==Nan always returns false.
-pete
Marco Hugentobler wrote:
> Hi,
> In QgsRasterLayer::drawMultiBandColor there is a section of code (line 2463)
> that is problematic for some files:
> if ( myRedValueDouble == noDataValueDouble || myRedValueDouble !=
> myRedValueDouble)
> #ifdef QGISDEBUG
>         //	QgsLogger::debug("myRedValueDouble", myRedValueDouble, __FILE__,
> __FUNCTION__, __LINE__, 1);
>         //	QgsLogger::debug("noDataValueDouble", noDataValueDouble, __FILE__,
> #endif
>         continue;
> I have a file where the noDataValueDouble for the first band is 0, so the
> method does not set pixel colors where red component is 0. This results in an
> image displayed in wrong colors. Is it ok if I replace the if-statement with:
> if(myRedValueDouble == noDataValueDouble && myGreenValueDouble ==
> noDataValueDouble && myBlueValueDouble == noDataValueDouble)
> My example image shows correctly like this.
> Regards,
> Marco
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: (212)-496-3488 or (212)-769-5742
Fax: (212)-313-7295 or (212)-769-5292
Web: http://cbc.amnh.org
Web: http://geospatial.amnh.org
Open Source, Open Mind.
...evolving through community cooperation to change the world bit by bit
