[Qgis-developer] Project Responisibilities and 0.9 Release
lists at dwillis.gotadsl.co.uk lists at dwillis.gotadsl.co.uk
Thu Aug 16 17:08:19 EDT 2007
On Thursday 16 August 2007 21:51, you wrote:
> On 8/16/07, lists at dwillis.gotadsl.co.uk <lists at dwillis.gotadsl.co.uk> wrote:
> > On Thursday 16 August 2007 15:26, you wrote:
> > > Meanwhile I am working on Eclipse and Visual C++ Express as IDE's for
> > > Qgis development. Qt4 works fine with Microsoft compilers just the
> > > CMake files need a bit of fixing up, anyone done any progress on this ?
> > I posted a patch for this a few weeks back. I've not updated my source
> > since then but I assume that it all still works. If you want I can repost
> > it.
> Hi David,
> sorry I wanted to write you earlier - I wanted to commit your patch
> but I had compilation problems with it due incompatibilities between
> MinGW and MSVC compilers. Have you been successful with MinGW
> compilation?
I've not tried. Could you let me know what the compilation problems were? I'm
guessing that I've missed out a #ifdef _MSC_VER somewhere. I should probably
check it on Linux too. I'm currently in the middle of getting Linux up and
running on my laptop so that should be a good workout for it...
David
