[Qgis-developer] x86_64 support
Otto Dassau
otto.dassau at gmx.de
Thu Aug 30 12:19:24 EDT 2007
On Thu, 30 Aug 2007 12:41:27 -0300
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi Douglas
> My apologies for not replying to you immediatly. Currently I dont have
> an x64 machine to test on. Does anyone else have access to one? Marco
> or Otto?
no - sorry, I don't have x64 installations running.
Otto
> Regards
> Tim
> 2007/8/24, Douglas E. Warner <silfreed at silfreed.net>:
> > On Tuesday 31 July 2007, Douglas E. Warner wrote:
> > > I'm working on a bug for the packages I built for Fedora where the plugins
> > > aren't found for x86_64.
> > > (https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=247549)
> > > I'm thinking this has to do with the fact that qgis is hard-coded to
> > > install to /usr/lib, where the default path for libraries on x86_64 is
> > > /usr/lib64. I've created a patch to install the libraries and plugins to
> > > this directory, but it appears that qgis is still looking in the wrong
> > > place somehow.
> > I was curious if anyone had a chance to look into the library installation
> > problem on 64 bit architectures. Should I create a bug for this issue?
> > -Doug
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
