[Qgis-developer] Problem with large attribute tables
Otto Dassau
otto.dassau at gmx.de
Sun Dec 2 04:01:56 EST 2007
Hi Marco,
thanks for your svn fix but get still the same error.
QIconvCodec::convertToUnicode: using ASCII for conversion, iconv_open failed
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Abgebrochen (core dumped)
Cannot access memory at address 0xb7fb7654
regards,
Otto
On Sat, 1 Dec 2007 16:54:37 -0200
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi
> This is really a side effect of ticket
> https://svn.qgis.org/trac/ticket/135
> The table display needs to be redesigned to use qt interview
> framework. I have some in progress work to do this, and martin has
> been doing some similar work in python.
> Regards
> Tim
> 2007/12/1, Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch>:
> > The exception catching is in svn now. Though I didn't test it because it
seems
> > to take a very long time until virtual memory is really finished (delayed by
> > swapping actions of the os).
> > Marco
> > On Saturday 01 December 2007 15:56:23 Marco Hugentobler wrote:
> > > Hi Otto,
> > > The problem is that you run out of virtual memory (RAM and swap partition
> > > are full) and so the bad_alloc exception is thrown.
> > > In the short run we should add a try/catch block and in the long run not
> > > read all the rows into memory. Please write a bug report about it.
> > > Regards,
> > > Marco
> > > Maybe we should
> > > On Saturday 01 December 2007 13:07:29 Otto Dassau wrote:
> > > > Hi,
> > > > I tried to open the database table of a very large shape file.
> > > > dbf -> 770 MB
> > > > shp -> 384 MB
> > > > shx -> 7 MB
> > > > Loading and visualizing the file works fine, although it takes some
> > > > minutes, but opening the attribute table fails.
> > > > The error message is:
> > > > failed terminate called after throwing an instance of 'std::bad_alloc'
> > > > When I generate a stacktrace, all it says is:
> > > > #0 0xffffe410 in ?? ()
> > > > Cannot access memory at address 0xbf8e8520
> > > > Before I write a bug report I would like to ask if maybe someone else
has
> > > > similar experiences. I thought it might be an encoding problem first,
but
> > > > I checked and the encoding of the shape file is utf-8 and my system
> > > > encoding, too.
> > > > kind regards,
> > > > Otto
> > > > _______________________________________________
> > > > Qgis-developer mailing list
> > > > Qgis-developer at lists.qgis.org
> > > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > Dr. Marco Hugentobler
> > Institute of Cartography
> > ETH Zurich
> > Technical Advisor QGIS Project Steering Committee
