[Qgis-developer] question about r.in.xyz
PikoBoZ
piklas at gmail.com
Tue Dec 4 07:59:23 EST 2007
Hi list
I'd like to use r.in.xyz from a python plugin in the aim to extract the
x,y,z values of a tiff dem file to an ascii file. I know that grass tools
aren't supported yet in PyQGIS, but i'm going to call directly the
r.in.xyz.exe of the grass directory with an os command. I have actually two
questions
How can set any loaded dem layer as the current layer to work with ?
Can I specify arguments into a os.system command as in a traditionnal grass
command
os.system('r.in.ascii.exe') input=~/CURRENT LAYER output=rast
Which python syntax or os command must i use to do that ?
Many Thanks 4 answers
PikO
View this message in context: http://www.nabble.com/question-about-r.in.xyz-tf4942926.html#a14150060
Sent from the qgis-developer mailing list archive at Nabble.com.
