[Qgis-developer] remaining map composer bug(s) [was: QGIS 0.9.2 release plans (and new bug triage!)]
Steven Bell botsnlinux at gmail.com
Fri Dec 7 17:15:55 EST 2007
In theory, yes, the same workaround can be applied.  However, that code also
handles label drawing in the normal map view, so I'm reluctant to change it
on the verge of a release.  If Tim deems it ok, and someone has time to do
it, it probably isn't that difficult.  Unfortunately, I really have no time
at all between now and next Tuesday.   However, I hope to do some more
serious work on the composer over Christmas break.
Steven
On Dec 7, 2007 3:57 PM, Maciej Sieczka <tutey at o2.pl> wrote:
> Tim Sutton wrote:
> > Hi
> > I beleve that its just the new splitter Gavin or Steven added. Try to
> > look on the right of the window for a splitter bar and pull it over to
> > the left. I had the same problem when the changes first went into svn
> > and it was resolved by just pulling open the splitter bar.
> Tim is correct.
> However, there is a real bug overseen in the map composer -
> label fonts (I mean the labels one sets with layer
> Properties -> Labels, not the "Add new label" tool in map
> composer) are garbled most of the time in "render" mode, and
> unredable small in "cache" mode.
> It seems to me that this bug could use the same workaround
> which Steven Bell applied for fonts in the legend and scale
> tools of map composer. Is this correct? Could it be still
> done for 0.9.1, if so?
> Maciek
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20071207/3832f04b/attachment.html
