[Qgis-developer] UTF-8 Filenames, SVN, Qt and Macs
Tom Elwertowski telwertowski at comcast.net
Sun Dec 9 21:06:13 EST 2007
Hi all (especially Mac builders),
Since a UTF-8 filename was recently added to svn and the filename is
also read as text from the AUTHORS file, here are some Mac notes
regarding the use of UTF-8 filenames and text.
1. Mac users need to define LC_CTYPE to use svn with UTF-8 filenames.
2. Developers should call setCodec("UTF-8") when reading UTF-8 content
using QTextStream.
If LC_CTYPE has not been defined, you will encounter the error:
svn: Can't convert string from 'UTF-8' to native encoding:
To get past this, define the following (locale can vary):
export LC_CTYPE=en_US.UTF-8
There are still some problems but I think they are due to the bash shell
distributed with OS X 10.4. Installing a newer one is rumored to help
but you can also just ignore the following:
'ls' will display ?? for each UTF-8 character.
'svn status' will respond with both a '!" (file is missing) and '?'
(extra file is present) for any file with a UTF-8 filename. This results
in a 'M' (modified) in the version number even when nothing is modified.
Since the AUTHORS file also contains UTF-8, setCodec("UTF-8") must be
called for a QTextStream reading the file. Linux reads UTF-8 by default
but the Mac does not.
Tom
