[Qgis-developer] New Installer for Qgis 0.9.1 for Windows
Leonardo Lami
lami at faunalia.it
Mon Dec 10 12:44:24 EST 2007
> To not have the SQLite driver would be sad...
>> Markus do you know why that?
> No idea- you need to have SQLite present (including devel files)
> to get the driver compiled. But it's known to work on Windows AFAIK.
> Best
> Markus
Somethings about testing:
- When I open QGIS it say "PyQt bindings missing" and so Python support
is disable
- using GRASS modules the supported driver seem to be only pg,ogr and
dbf. But if I use dbf default driver and I try to import a sahpe with
v.in.ogr or I create, in any way, a new GRASS vector , I see that QGIS
does'nt create the dbf linked table.
So I think there are some problem about general driver database support.
- If you open a GRASS mapset, when you want close it with the rigth
buttom it say "Cannot close mapset. Cannot remove mapset lock
C:/...../$mapset/.gislock. In fact the file is not create when you open
the mapset.
Other tests are coming....
regards
leonardo
