[Qgis-developer] New Installer for Qgis 0.9.1 for Windows[Scanned]
Tisham Dhar tisham at apogee.com.au
Mon Dec 10 18:11:48 EST 2007
Hi All,
I may not have SQLite setup in my build environment. It has not been
requested. I will put it in today's builds. I usually make one every day
during the Qgis release period.
Regards,
Tisham.
-----Original Message-----
Sent: Tuesday, 11 December 2007 8:01 AM
To: Leonardo Lami
Cc: Otto Dassau; Tisham Dhar; qgis-developer at lists.qgis.org
Subject: Re: [Qgis-developer] New Installer for Qgis 0.9.1 for
Windows[Scanned]
On Mon, Dec 10, 2007 at 02:35:32PM +0100, Leonardo Lami wrote:
> Otto Dassau ha scritto:
> >>> Hi Tisham,
> >>> maybe I just haven't found it but can you tell, what database
drivers
> >>> (sqlite,
> >>> pg, mysql, odbc) are supported for the GRASS version you
integrated? And
> >>> what
> >>> file formats are supported by gdal/ogr?
> >>> thanks a lot
> >>>  Otto
> >>> On Mon, 10 Dec 2007 21:59:47 +1000
> >>> tisham at apogee.com.au wrote:
> >> I see that the support is present in v.in.ogr command in GRASS 6.3
csv
> >> but it was not present in the QGIS.0.9.1.09_12.
> >> Now i'm going to test the new release!
> >> See you later
> >> Regards
> >> Leonardo
> The new test on
> http://whatnick.dyndns.org:8080/tisham/qgis_setup0.9.1.10_12_2007.exe
> confirm the absence of the driver for SQLite infact if I see the
db.connect command by GRASS shell in QGIS I see that the supported
drivers are only dbf,ogr and pg.
> It is strange because the GRASS version used seems to be GRASS
6.3.ORC3 while in GRASS scv for Linux the SQLite driver is present.
To not have the SQLite driver would be sad...
> Markus do you know why that?
No idea- you need to have SQLite present (including devel files)
to get the driver compiled. But it's known to work on Windows AFAIK.
Best
Markus
