[Qgis-developer] Python build problem on OSX
Tom Elwertowski telwertowski at comcast.net
Wed Dec 19 00:48:44 EST 2007
William Kyngesburye wrote:
> I found a build problem (unnoticed back in 0.9.0) with the Python
> support on OSX - it will NOT build universal, or with an SDK (which
> means I can't build *on* Leopard *for* Tiger, due to some library
> version incompatibilities).
I work around the problem by editing the two generated Makefiles in
build/python/core and build/python/gui after the C++ generation step is
finished.
To CFLAGS and CXXFLAGS add
-isysroot /Developer/SDKs/MacOSX10.4u.sdk -arch i386 -arch ppc
To LFLAGS add
-Wl,-syslibroot,/Developer/SDKs/MacOSX10.4u.sdk -arch i386 -arch ppc
This can be done after the build is done or you can interrupt the build
as soon as you see the message that it's starting compilation of
core.so. I also delete any .o in the two directories. Running 'make'
again will (re)build Universal modules.
The problem is that the QGIS Python modules are completely managed by a
Python script. If the generated files were directly compiled by CMake,
the problem would disappear. This would also solve the problem of all
C++ files being regenerated and recompiled whenever any file, not just
those which have a modified Python binding, is modified. It would make
more sense to me if each sipxxx.cpp depended upon xxx.sip and Python was
invoked only to generate the .cpp file leaving CMake to take care of
compiling and linking C++ files.
Tom
