[Qgis-developer] plugins installer
John C. Tull john.tull at wildnevada.org
Fri Dec 28 22:46:59 EST 2007
On Dec 28, 2007, at 7:46 PM, John C. Tull wrote:
> Despite Paolo's followup comment about mkdir, and the fact that I
> did the same a few weeks ago and installed the ImageMap plugin at
> that time, I cannot install the BetterTable plugin (only one I
> tried) now using most recent svn. I get the same permissions error
> noted below. The double-slash should have no effect on this to my
> knowledge. Any other ideas?
> Cheers,
> John
> On Dec 16, 2007, at 9:50 AM, Paolo Cavallini wrote:
>> Hi all.
>> Testing the (very nice) python plugin installer (fresh qgis from
>> svn), I
>> get an error:
>> Failed to unzip file to /home/paolo/.qgis//python/plugins ... check
>> permissions
>> Is this just a double slash problem? Any solution to this at the
>> horizon?
>> also, it would be good to use the same installer plugin to install
>> also
>> plugins from filesystem: is it feasible to add this feature?
>> BTW: http://spatialserver.net:3001/ mention a bug (#781) which has
>> been
>> closed: better update the info?
>> All the best.
>> Paolo Cavallini, see: http://www.faunalia.it/pc
>> Qgis-developer mailing list
>> Qgis-developer at lists.qgis.org
>> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
