[Qgis-developer] QGIS and platforms
    Tom Russo
    tom.km5vy at gmail.com
    Fri Feb  2 01:09:15 EST 2007
On 2/1/07, Martin Dobias <wonder.sk at gmail.com> wrote:
> On 2/2/07, Tom Russo <tom.km5vy at gmail.com> wrote:
> > That does sure look like it's trying to get the QMAKE_LIBS_THREAD
> > stuff out of qmake, but isn't getting anything.
> I think I know what's going on here - on FreeBSD, QMAKE_LIBS_THREAD is
> empty and there's another variable used instead: QMAKE_LFLAGS_THREAD =
> -pthread
Yes, that is what I see in
/usr/local/Trolltech/Qt-4.2.2/mkspecs/freebsd-gcc++/qmake.conf
> So it seems that FindQt4 macro is not ready for this situation. If so,
> we should report it to CMake developers - but could you please check
> first whether this problem stays also in latest CMake release?
> And for the current situation - will setting CMAKE_SHARED_LINKER_FLAGS
> in ccmake to "-pthread" help to continue the build?
Adding "-DCMAKE_SHARED_LINKER_FLAGS=-pthread" to the cmake line does
indeed allow the compile to continue past where it was dying earlier.
Now, instead of getting linker errors in making the qgis_gui library
at 30%, it gets to 59% and complains so:
[ 59%] Building CXX object src/app/CMakeFiles/qgis.dir/moc_qgspythondialog.o
Linking CXX executable qgis
/usr/local/Trolltech/Qt-4.2.2/lib/libQtCore.so: undefined reference to
`pthread_cleanup_pop'
and so forth.
Tom Russo    KM5VY   SAR502   DM64ux          http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 http://kevan.org/brain.cgi?DDTNM
"And, isn't sanity really just a one-trick pony anyway? I mean all you get is
 one trick, rational thinking, but when you're good and crazy, oooh, oooh,
 oooh, the sky is the limit!"  --- The Tick
