[Qgis-developer] Re: qgssvnversion.h and compile problem
Martin Dobias wonder.sk at gmail.com
Thu Feb 8 02:49:23 EST 2007
I think this is due some of the recent commits which were made to fix
compilation with 'MSYS Makefiles' generator and probably has broken
'MinGW Makefiles'.
I think Tim has a definite and much better solution for showing SVN
revision, with that fix we should be able to forget all these
problems.
If you're asking for an immediate solution, just edit qgssvnversion.h
and delete the backslashes.
Martin
On 2/8/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
> Dear developers,
> I have a problem when I compile svn head.
> D:\devel\workplace\unstable\qgis_head\build>cmake -G "MinGW Makefiles"
> -DGRASS_P
> REFIX=D:\devel\bin\msys\local\grass-6.3.cvs
> -DCMAKE_INSTALL_PREFIX=D:\devel\work
> place\unstable\qgis_head\apps D:\devel\workplace\unstable\qgis_head
> -- Found Proj: D:/devel/bin/msys/local/lib/libproj.a
> -- Found Sqlite3: D:/devel/bin/msys/local/lib/libsqlite3.a
> -- Found GEOS: D:/devel/bin/msys/local/lib/libgeos.dll.a
> -- Found GDAL: D:/devel/bin/msys/local/lib/libgdal.dll.a
> -- Found PostgreSQL: D:/devel/bin/msys/local/lib/libpq.dll
> -- Found Expat: D:/devel/bin/msys/local/lib/libexpat.dll.a
> -- Using GSL from D:/devel/bin/msys/local
> -- Found GRASS: D:/devel/bin/msys/local/grass-6.3.cvs (6.3.cvs)
> -- Found Qt-Version 4.2.2
> -- Configuring done
> -- Generating done
> -- Build files have been written to:
> D:/devel/workplace/unstable/qgis_head/build
> D:\devel\workplace\unstable\qgis_head\build>make
> [  0%] Built target svnversion
> [  8%] Built target ui
> [  9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.obj
> In file included from
> D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:4:
> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1: error: stray
> in program
> invalid to
> ken
> `define' d
> oes not name a type
> in program
> missing te
> rminating " character
> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1:49: warning:
> backs
> lash and newline separated by space
> backs
> lash-newline at end of file
> D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:13: error:
> `QGSSVNVERSIO
> N' was not declared in this scope
> mingw32-make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgis.obj] Error 1
> mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> mingw32-make: *** [all] Error 2
> After that I had lookup
> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h it was include
> following line:
> \ #define QGSSVNVERSION \"svn_rev_unavailable\" \
> Best regards,
> Byambaa Mendbayar
