[Qgis-developer] how to configure Kdevelop within Cmake
Byambaa Mendbayar mendbayar_b at mongol.net
Thu Feb 22 23:52:10 EST 2007
Dear Tim, Martin and Devels,
I have following
http://wiki.qgis.org/qgiswiki/Setting_Up_Kdevelop_For_QGIS_Developement
instruction for developing and debugging for QGIS. But I have not successes.
I have been using QGIS SVN head and branch Release 0.8.0.
What type of I will use for CMake instead of "Project Type : Generic C++
Automake Based".
When I was compiling 0.8.0 release code using Kdevelop, it was make that:
cd '/home/mende/workplace/qgis_0.8.0' && WANT_AUTOCONF_2_5="1"
WANT_AUTOMAKE_1_6="1" make -k
make all-recursive
Making all in src
Making all in core
make all-am
compiling qgscontexthelp.moc.cpp (g++)
compiling libqgis_core_la-qgscontexthelp.moc.o (g++)
qgscontexthelp.moc.cpp:15:34: error: private/qucomextra_p.h: No such file or
directory
qgscontexthelp.moc.cpp:17:2: error: #error "This file was generated using
the moc from 3.3.6. It"
qgscontexthelp.moc.cpp:18:2: error: #error "cannot be used with the include
files from this version of Qt."
qgscontexthelp.moc.cpp:19:2: error: #error "(The moc has changed too much.)"
qgscontexthelp.moc.cpp:22: error: no 'const char*
QgsContextHelp::className() const' member function declared in class
'QgsContextHelp'
qgscontexthelp.moc.cpp:27: error: 'QMetaObject* QgsContextHelp::metaObj' is
not a static member of 'class QgsContextHelp'
qgscontexthelp.moc.cpp:28: error: 'QMetaObjectCleanUp' does not name a type
qgscontexthelp.moc.cpp:31: error: redefinition of 'static QString
QgsContextHelp::tr(const char*, const char*)'
qgscontexthelp.h:46: error: 'static QString QgsContextHelp::tr(const char*,
const char*)' previously defined here
qgscontexthelp.moc.cpp: In static member function 'static QString
QgsContextHelp::tr(const char*, const char*)':
qgscontexthelp.moc.cpp:34: error: cannot convert 'QString(((const
QString&)(((QApplication*)QCoreApplication::instance()), ((const QString*)(&
QCoreApplication::translate(const char*, const char*, const char*,
QCoreApplication::Encoding)(s, c, CodecForTr))))))' from type 'QString' to
type 'QString&'
qgscontexthelp.moc.cpp:36: error: cannot convert 'QString::fromLatin1(const
char*, int)(-0x00000000000000001)' from type 'QString' to type 'QString&'
qgscontexthelp.moc.cpp: At global scope:
qgscontexthelp.moc.cpp:39: error: redefinition of 'static QString
QgsContextHelp::trUtf8(const char*, const char*)'
qgscontexthelp.h:46: error: 'static QString QgsContextHelp::trUtf8(const
char*, const char*)' previously defined here
Best regards,
Byambaa Mendbayar
