[Qgis-developer] Extending QgsMapToolIdentify andQgsIdentifyResults
Byambaa Mendbayar mendbayar_b at mongol.net
Wed Jan 31 23:48:09 EST 2007
Dear Martin Dobias and Peter Ersts,
I am glad to hear extending QgsMapToolIdentify within QgsIdentifyResults. I
like your idea.
I have some idea for few plug-ins. One of them requires user assigned extend
coordinate select by mouse click event on the map canvas. Actually this
plug-in will be used raster image warping like as gdalwarp util.
Feel a free to advice and helping to me for above plug-ins work.
P.S I'm looking forward to see the suggestion and patches from you on
QgsMapToolIdentify and QgsIdentifyResults.
Byambaa Mendbayar
-----Original Message-----
[mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Peter Ersts
Sent: Saturday, January 27, 2007 5:41 AM
To: Martin Dobias
Cc: qgis-developer at lists.qgis.org
Subject: Re: [Qgis-developer] Extending QgsMapToolIdentify
Martin,
For the most part the results that are displayed now are sufficient but
here is a list of things that could be useful
All Results to include:
Map coordinate (projected)
Map coordinate (geographic)
Display coordinates, i.e., X,Y within the display (lower priority)
Layer type
Vector Specific:
Feature ID + all associated attributes (table values)
length or area of feature if not already in table (lower priority)
Raster Specific:
Pixel Coordinate
Pixel values (all bands)
Pixel count (for classified/categorical data)
WMS Specific:
For simplicity the result set could include more meta-data type
information about the layer, but that is not necessarily needed as that
information is readily available using QgsInterface::getActiveLayer().
For the actual storage of the results an xml document would be robust,
but could add a little overhead.  Or, for everything but the vector
feature attributes and the pixel values, a simple struct could be used.
Vector feature and Pixel values could be a QList of another struct that
is just an attribute name and value, so for raster it would be
attribute=Band1 value=50 etc.
Anyway, thanks for thinking about this. I know there are a lot of other
things to do but I think this would be a useful modification that would,
for example, allow a plugin to respond differently to points based on a
particular attribute i.e., loading an external file (path/url in
attribute) with the correct application (depending the file type stored
in another attribute).
cheers,
-pete
Martin Dobias wrote:
> Hi Peter,
> your idea sounds good for me. But could you explain how should
> QgsIdentifyResult object look like? I mean what will be its contents
> for vector/raster layers - e.g. only feature ID (for vector layers)
> and cell coordinate (for raster layers) or whether it will contain
> also more information etc.
> Martin
> On 1/26/07, Peter Ersts <ersts at amnh.org> wrote:
>> Dear Developers,
>> I was wonder if it would be possible to disassociate the
>> QgsIdentifyResults from a QWidget? My suggestions is to make
>> QgsIdentifyResults a more generic object. This would allow for any class
>> (or plugin) to implement QgsMapToolIdentify. The QgsMapToolIdentify
>> mouse event would simply return a QgsIdentifyResult object that could
>> then be displayed by the user or used to obtain attributes for the
>> feature or pixel at the screen/map coordinates.
>> For example, I have been working on some modifications to the
>> QgsRasterLayer and QgsRasterLayerProperties classes (and gui) to allow
>> for basic stretching and multiple user defined transparency values.  One
>> of the feature that was suggested was to have a "Identify Features" like
>> tool to populate the transparency tables. In this example, the user
>> would press a button "Add Values From Display" which I would like to
>> launch a QgsMapToolIdentify like feature, but return the results as a
>> simple object to QgsRasterLayerProperties.  QgsRasterLayerProperties
>> would then use the results to populate a table in gui rather than simply
>> display the pixel values in another dialog.
>> This would also allow users to inherit and extend the functionality of
>> QgsMapToolIdentify. It seems like it should not be to difficult, but I
>> may be missing something here.
>> cheers,
>> -pete
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: (212)-496-3488 or (212)-769-5742
Fax: (212)-313-7295 or (212)-769-5292
Web: http://cbc.amnh.org
Visit the Indo-South Atlantic Consortium on Humpback Whales
Web:  http://www.isach.org
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
