[Qgis-developer] Build version 0.8.1 with Visual C++ 2005 Express
Tim Sutton tim at linfiniti.com
Sat Jul 7 08:29:30 EDT 2007
Hi David
Excellent stuff, Do you think you will be able to port your work to
trunk? I can aply your patch to 0.8.x branch but at this stage I am
unsure if there will be a 0.8.2 release or if we will proceed directly
to the release of 0.9.0 - so it would be a great addition to the trunk
of QGIS.
Regards
Tim
2007/6/28, David Willis <lists at dwillis.gotadsl.co.uk>:
> For anyone who's interested, I now have QGIS 0.8.1 building with the
> express edition of Visual C++ 2005. Code and cmake file changes are in the
> included patch. If anyone has any suggestions for making this neater, or
> anything at all really, let me know.
> This includes all the standard plugins bar GRASS. I've not tried any of
> them properly yet but the GPX and GPS plugins load their GUIs ok.
> Notes:
> Of the various dependencies, only the ones that required work beyond
> simply installing are listed here.
> Visual studio set up using the instructions in the QGIS wiki.
> Qt 4.2.3 built using instructions in the QGIS wiki.
> GDAL 1.4.1 from http://vterrain.org/Distrib/gdal.html
>         Also need to add the following include dirs to gdal_rasterize project:
>         ..\..\gcore;..\..\port;..\..\alg;..\..\ogr
> GEOS by svn from http://mateusz.loskot.net/projects/geos/
>         Also need to copy capi\geos_c.h.in to geos_c.h
> GSL from
> http://david.geldreich.free.fr/downloads/gsl-1.9-windows-sources.zip
> PostGIS from PostGIS website. Needed to add .lib extension to libpq.a and
> libpostgres.a
> QGIS: Need to find stdint.h and unistd.h. unistd.h comes with GnuWin32
> version of flex & bison binaries. stdint.h from
> http://www.azillionmonkeys.com/qed/pstdint.h.
> Once the solution is generated with cmake, the properties of the qgis
> project need to be modified as follows (for the debug configuration only):
> Open project properties and go to Configuration Properties --> Linker -->
> System. Change Windows to Console.
> I added the various dependency dlls (GEOS, GDAL etc) to the installation
> bin directory by hardlinking with the dlls in their original directories
> (fsutil hardlink create). It might be better to do this by adding them to
> the path...
> Debugging QGIS currently needs to be done by running from the install
> directory and using Debug --> Attach to Process...
> David Willis
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release  Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
