[Qgis-developer] QGIS 0.8.1 preview 3 available (windows)
Magnus Homann magnus at homann.se
Sun Mar 18 08:42:28 EDT 2007
Tim Sutton wrote:
> There have been various other tweaks, bug fixes and improvements.
> Before installing I suggest you remove any previously installed copy
> of QGIS, or install into a separate directory. If you don't do this,
> you may find you get duplicated plugins dues to some changes that have
> been made in the build process.
Also the wrong providers can be picked up if you don't remove the old
ones. I suggest *it is mandatory* instead of a suggestion to remove the
old installation or install to new directory.
It is due to the CMake build system using other names.
Magnus
Magnus Homann
magnus at homann.se
+46 702 399 558
