[Qgis-developer] 0.9 revision 6830: Query builder on postgis layer broken
Tom Elwertowski telwertowski at comcast.net
Wed Mar 28 15:58:46 EDT 2007
John C. Tull wrote:
> So far, this has been solid enough for some production work on a basic
> map. I found a bug with postgis layers though. If I add a postgis layer,
> I can build a query prior to adding the layer with no problems. If I
> view the properties of that layer and click the query builder button, I
> am not presented with a dialog to make changes to my query. Effectively
> I have to add a new layer with the proper query and delete the prior layer.
> This is built from revision 6830 in trunk that I checked out last
> Friday. I have submitted a ticket on this as well under Milestone
> Version 0.9.
Fixed in r6842.
Tom
