[Qgis-developer] QGIS crash on Mac OS X -- 0.8 release branch
Tom Elwertowski telwertowski at comcast.net
Sat May 12 00:43:50 EDT 2007
Gary Sherman wrote:
> I've tried the complete rebuild several times, changing minor things.
> Still no luck. Since my build failed on Tim's system, it seems like it's
> something particular to my setup. But I'm not doing anything different
> than previous builds, except this is on a new machine (intel).
I discovered how to reproduce your crash in
QgsOgrProvider::loadFields(). I did it by building with frameworks
rather then traditional libraries.
In my case, I have dependent packages present in both
/Library/Frameworks and /usr/local. For at least some "#include <...>"
statements, the build is reading from /usr/local instead of
/Library/Frameworks. If I rename the header in /usr/local, it then uses
the one in /Library/Frameworks. If I introduce an error into the header
in /usr/local, the build fails.
I checked a handful of cmake generated files and the paths are what I
expect. Plenty of -I/Library/Frameworks/xxx.framework/Headers and no
-I/usr/local/include so I am baffled as to why I end up with an
inconsistent build.
This makes me wonder if you have some non-framework headers which are
being picked up and producing an inconsistent build.
Tom
