[Qgis-developer] QGIS crash on Mac OS X -- 0.8 release branch
Gary Sherman sherman at mrcc.com
Mon May 14 00:42:57 EDT 2007
Great detective work guys. Thanks.
-gary
On May 13, 2007, at 7:20 PM, Tom Elwertowski wrote:
> William Kyngesburye wrote:
>> On May 13, 2007, at 2:07 AM, Gary Sherman wrote:
>>> I installed your (William's) GRASS 6.3-cvs package and now
>>> everything seems to work.
>>> It did not work with the GRASS 6.2 package.
>> huh.  I wonder if just the version numbering is the key.  Just a
>> thought, but if GDAL loads its grass 6.2 libs, then Qgis tries to
>> load another set of 6.2 libs, the OSX linker may be trying to be
>> smart and using one that's already loaded, but they're just
>> different enough from what Qgis expects to cause problems.  But
>> with Qgis+GRass 6.3, the linker sees 6.3 as different enough to
>> load those libraries also.
> I found the problem. The path references in GRASS 6.2 libs have an
> extra (non-existent) directory:
> /Applications/GRASS.app/Contents/Resources/grass-6.2.1/lib/
> libgrass_gis.dylib
> The libs in 6.3 don't:
> /Applications/GRASS.app/Contents/Resources/lib/libgrass_gis.dylib
> If I create the following link for GRASS 6.2:
> ln -s . /Applications/GRASS.app/Contents/Resources/grass-6.2.1
> QGIS can load shp files without crashing and without starting GRASS.
> QGIS is probably working ok inside GRASS 6.2 because GRASS has
> already loaded the libraries and QGIS doesn't need to use the path
> info to find them.
> Tom
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
   *Geospatial Hosting
   *Web Site Hosting
"We work virtually everywhere"
