[Qgis-developer] Development needed: Georeferencer plugin
Sebastian Schmitz sebastian.schmitz at wheregroup.com
Tue May 22 06:19:31 EDT 2007
is that based on latest SVN or based on qgis 0.8 release?
Cheers
Sebastian
Oleg Gusev schrieb:
> Am Dienstag, 22. Mai 2007 10:12 schrieb Sebastian Schmitz:
>> In the georeferencer plugin dialogue, instead of having a pop up box to
>> type in coordinates users want to use the mouse to pick the coordinates
>> from the main map window and attribute them to the same point in the not
>> yet georeferenced image.
> Hi Sebastian,
>  i've already done it in a quick-and-dirty way by hooking the
>  right mouse click on a canvas widget.
>  Maybe somebody can do it better by creating
>  a MapTool instead. The georeferencer widget needs a lot
>  of modifications to be usable anyway.
>  SVN diff is attached.
>  Oleg.
> Index: src/plugins/georeferencer/mapcoordsdialog.cpp
> --- src/plugins/georeferencer/mapcoordsdialog.cpp	(Revision 6894)
> +++ src/plugins/georeferencer/mapcoordsdialog.cpp	(Arbeitskopie)
> @@ -32,3 +32,9 @@
>    reject();
> +void MapCoordsDialog::setXY(QgsPoint & xy)
> + leXCoord->insert(QString::number(xy.x(),'f',7));
> + leYCoord->insert(QString::number(xy.y(),'f',7));
> Index: src/plugins/georeferencer/mapcoordsdialog.h
> --- src/plugins/georeferencer/mapcoordsdialog.h	(Revision 6894)
> +++ src/plugins/georeferencer/mapcoordsdialog.h	(Arbeitskopie)
> @@ -30,6 +30,8 @@
>    void on_buttonOk_clicked();
>    void on_buttonCancel_clicked();
> +  void setXY(QgsPoint &);
>  private:
>    QgsPoint mPixelCoords;
> Index: src/plugins/georeferencer/qgspointdialog.cpp
> --- src/plugins/georeferencer/qgspointdialog.cpp	(Revision 6894)
> +++ src/plugins/georeferencer/qgspointdialog.cpp	(Arbeitskopie)
> @@ -443,6 +446,7 @@
>    MapCoordsDialog* mcd = new MapCoordsDialog(pixelCoords, this);
>    connect(mcd, SIGNAL(pointAdded(const QgsPoint&, const QgsPoint&)),
>            this, SLOT(addPoint(const QgsPoint&, const QgsPoint&)));
> +  connect(mIface->getMapCanvas(),SIGNAL(sendXY(QgsPoint&)),mcd,SLOT(setXY(QgsPoint&)));
>    mcd->show();
> Index: src/gui/qgsmapcanvas.cpp
> --- src/gui/qgsmapcanvas.cpp	(Revision 6894)
> +++ src/gui/qgsmapcanvas.cpp	(Arbeitskopie)
> @@ -636,6 +636,13 @@
>    mCanvasProperties->mouseButtonDown = true;
>    mCanvasProperties->rubberStartPoint = e->pos();
> +  if (e->button() ==  Qt::RightButton )
> +    QPoint xy = e->pos();
> +    QgsPoint coord = getCoordinateTransform()->toMapCoordinates(xy);
> +    emit sendXY(coord);
>  } // mousePressEvent
> Index: src/gui/qgsmapcanvas.h
> --- src/gui/qgsmapcanvas.h	(Revision 6894)
> +++ src/gui/qgsmapcanvas.h	(Arbeitskopie)
> @@ -275,6 +275,7 @@
>      void setProgress(int,int);
>      /** emits current mouse position */
>      void xyCoordinates(QgsPoint & p);
> +    void sendXY(QgsPoint & p);
>      //! Emitted when the scale of the map changes
>      void scaleChanged(double);
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
mailto:sebastian.schmitz at wheregroup.com
http://www.wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
