[Qgis-developer] Python bindings not available
Matthew Perry perrygeo at gmail.com
Tue May 22 11:56:18 EDT 2007
On 5/22/07, Düster Horst <Horst.Duester at bd.so.ch> wrote:
> I'm trying to use the Python bindings of QGIS 0.9 but I do have some
> problems to run Python with QGIS. I configure the Python bindings with
> ccmake. All looks fine. cmake says:
>  -- Python libraries found
>  -- Python bindings enabled
> All looks succesful anyway. But when I start QGIS a window appears with the
> Message:
> "Couldn't load QGIS bindings. Python support will be disabled"
Start up python and try to import the qgis module (eg "from qgis
import core"). Do you get any errors?
Matthew T. Perry
http://www.perrygeo.net
"You never change things by fighting the existing reality.
To change something, build a new model that makes
the existing model obsolete" - R. Buckminster Fuller
