[Qgis-developer] CMake error on HEAD
Martin Dobias wonder.sk at gmail.com
Tue May 22 16:51:00 EDT 2007
I haven't seen this problem yet. Will it help if you set the libraries
manually? Are they at some unusual place? CMake's FindQt4 module
searches for them with FIND_LIBRARY comand which should be able to
find them in standard paths.
Martin
On 5/22/07, Mark Coletti <mcoletti at lychnobite.org> wrote:
> I get the following cmake error on a SuSE 10.1 machine:
>  CMake Error: This project requires some variables to be set,
>  and cmake can not find them.
>  Please set the following variables:
>  QT_FONTCONFIG_LIBRARY (ADVANCED)
>  QT_PNG_LIBRARY (ADVANCED)
>  QT_X11_m_LIBRARY
>  QT_ZLIB_LIBRARY (ADVANCED)
> I'm running cmake 2.4.6.
> The Qt4 is installed from rpm, btw.
> Cheers,
> Mark
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
