[Qgis-developer] [patch] debian packaging
Tim Sutton
tim at linfiniti.com
Sun Nov 4 18:48:54 EST 2007
Hi Jürgen
Actually this patch should not be neccessary. CMAKE FindGDAL uses
essentially the same mechanism too find GDAL related files. Those
lines are there because under Ubuntu Feisty gdal-config returns
incorrect values for the location of gdal libs etc. On Gutsy, Etch and
debian unstable you should simply be able to remove the following 2
lines:
-D GDAL_INCLUDE_DIR=/usr/include/gdal \
-D GDAL_LIBRARY=/usr/lib/libgdal1.3.2.so \
And everything related to GDAL should be found correctly. Give it a
try and if its not working for you I will revisit your patch. I will
eventually remove the above lines too once Feisty is a bit less in
use. At the moment I just do it manually before building packages that
dont need it.
Regards
Tim
2007/11/4, Jürgen E. Fischer <jef at norbit.de>:
> Hi there,
> the debian package doesn't build on unstable. The attached patch
> detect include path and library using gdal-config.
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member - Release Manager
Visit http://qgis.org for a great open source GIS
openModeller Desktop Developer
Visit http://openModeller.sf.net for a great open source ecological
niche modelling tool
Home Page: http://tim.linfiniti.com
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
