[Qgis-developer] [patch] MSVC patch (less warnings and GRASS)
lists at dwillis.gotadsl.co.uk lists at dwillis.gotadsl.co.uk
Mon Nov 5 19:00:21 EST 2007
> Great thanks - sorry if I missed that before somehow. Btw did you see
> that qt4.3.2 now builds under msvc ''out the box'' with no kludging?
Is that the non commercial one? I'll need to have a look at that.
> I've made a lib zip file with all the deps needed to build qgis except
> msvc. The idea is that you simply export LIB_DIR environment variable
> and then all the deps are automatically picked up for you. I just need
> to ensure all the find rules use the lib dir path (I've tested it over
> in openModeller which I built linked against qgis MSVC build). So with
> that I'll probably add an alternate section in your notes for folks
> like me who prefer to avoid building deps as much as possible.
Does that include GRASS and the python stuff yet..?
> Your notes are now in SVN trunk as of r7329..
Thanks Tim.
David
